Go Back   Volksforum.com > International > General > Who is who
  #261
Old 07-09-2009, 05:46
how about this. If you don't make it to h2o you'll have to post 20 pics of the car..... That'll encourage you to finish the damn thing.
Old 07-09-2009, 05:47
82dumptruck 82dumptruck is offline
agreed
Old 07-09-2009, 06:10
Chromosexual's Avatar
Chromosexual Chromosexual is offline
you guys suck
no new friends
Old 08-09-2009, 18:32
here's a lesson for you kiddies.
KW V3's dont go low
H&R Ultra Ultra's on their way.....
(2) Weber 45's on their way...
goddamn i am lucky i have a good job
no new friends
Old 08-09-2009, 23:08
..and unlucky with mk1's :/
no new friends
Old 09-09-2009, 04:32
KW V3's dont go low
wanna help fund my truck
Old 09-09-2009, 15:06
otti's Avatar
otti otti is offline
the v3´s go low enough when you are on 16´s.
they are made for actual suspension not for beeing stup hard
nobody has bad luck with mk1´s- they just have their own minds
belive me i know...
good for you that you have a good job, now stop whining and post some pics
of what was not low enough...
Old 09-09-2009, 22:55
Jens, you got my pic right?
no new friends
Old 10-09-2009, 17:41
rabfan rabfan is offline
Wow. the carbs were so done you had to order new ones? Yikes!
Old 10-09-2009, 19:55
Big Caddy's Avatar
Big Caddy Big Caddy is offline
couldn't get large jets to do squat (richen it up). kept running lean even with 60F9s on a stock motor. that would be way rich on my motor which is stock minus the cams.
I scratched my head many times.
79 golf gti wannabe.
Old 11-09-2009, 03:50
i so fucking hope this fixes this issue or no H20 for Louise
no new friends
Old 13-09-2009, 03:30
Old Guy's Avatar
Old Guy Old Guy is offline
Any good news Paulipoos?
Old 13-09-2009, 03:41
Steve I wont be able to get to the UPS store or get to the 78 until next Thursday. Cutting it so close its not funny.
no new friends
Old 13-09-2009, 06:07
Old Guy's Avatar
Where is the "biting my nails" icon when I need it.
Wish your 78 was on RJ's and my way to OC. We would be there in a heart beat to help. I'd rather help you get Louise going than to drink beer Thursday and Friday.
Wait, what did I just say?
Old 13-09-2009, 13:00
you just said some very kind words - thanks!
again i just hope we can get something fixed. car wont go into storage until i get it all sorted and i cant/wont work on my tdi until i do so..... and i really need to be driving the tdi right now.......................
no new friends
Old 14-09-2009, 16:06
Big Caddy's Avatar
Just so you have this and not forget it.
swapping carbs:
1. Remove linkage pin from lower ball socket joint (little clip that hooks over that keeps the joints from seperating) do not be rough with the ball and socket joint. the ball will break easily.
2. Remove three screws that secure your top linkage to carb top (right carb)
3. Remove remaining two screws on right carb top and five screws from left carb (careful with the floats)
4. Move carb tops and top linkage out of the way
You can swap to the new floats from your new carbs at this time. adjust the float level.
5. Sop out remaining fuel form carbs
6. Remove the 8 nuts that hold the carbs to the manifold (do not lose the washers or spring washers if they have them
7. pull the carbs from the manifold studs (do not lose the gaskets and their rubber rings
8. You may need to remove the trumpets from the carbs to allow for clearance first
9. Decide which carb you want on which side.........shouldn't matter
10. Install the linkage (sync scew and idle screws) on the new carbs.
11. There are flanges that bend over the butterfly nuts that keep them from turning. bend them and remove the nuts and reinstall them.
12. Mount the gaskets and make sure the O-rings don't fall out of place
13. Slide the new carbs on and install the nuts (do not over tighten)
14. The sync linkage should be fitting together now. don't worry about adjusting yet
15. Install the tops from your old carb (chrome ones you moved out of the way)
16. install the top linkage that you moved out of the way.
17. Hook up the section of linkage from the old carbs to the lower linkage.
18. insert the clip that holds it on.
double check everything.
while you have your carb tops off, check the float level.
Bottom left is the DCOE. you have square floats but they are about the same
Old 14-09-2009, 17:58
otti's Avatar
^woah, information overkill
paul you just have to do it!
get her done
i didnt get the pic though, so you have to come with louise that i can see her
Old 14-09-2009, 18:43
Big Caddy's Avatar
Paul understands why I posted a book of info much easier for him to just read it then for me to explain it to him.
Old 14-09-2009, 18:46
Big Caddy's Avatar
oh, and when you get it running for h2o. change the oil. I'm sure there has been a lot of fuel getting into the oil.
And bring your assless chaps again
Old 14-09-2009, 20:19
otti's Avatar
hey tom are you brnging your car to h2o as well??
joining us for the last leg of the c2c trip?
