Go Back   Volksforum.com > International > Technical > Watercooled projects
  #181
Old 12-03-2012, 10:12
VWAirlines's Avatar
VWAirlines VWAirlines is offline
Great project! I really enjoy reading it.
I'm working on an mk3 4motion project, and i'm using an Gen2 Haldex.
I'm trying to figure out how the controller works, because it needs the ABS signals, and what i am told is that the signals from mk2/3 ABS sensors are not the same as that from an mk5.
How are you going to setup your haldex controller?
Keep up the good work!
Old 12-03-2012, 10:28
2fast4you's Avatar
2fast4you 2fast4you is offline
TNX
I'll be using a complete wire ring harness from a Quattro car, and about the ABS signals... I started something ones but gave up
I will be doing something as Mario Bacher. You can see what he did on his web site http://www.golf2tfsi.de/html/2010.html
TUNINGGARAGE
REVO TECHNIK
Old 12-03-2012, 23:20
VWAirlines's Avatar
Thnx for the link!
As far as i can see he is still using his original abs sensors. If that's true i can keep the original sensors in combination with a mk5 abs pump for the canbus connection.
Looking forward to the next update!
Old 12-03-2012, 23:58
2fast4you's Avatar
Thnx for the link!
No!!!
He is using an MK5 ABS magnetic rings and MK5 ABS sensors. The ABS rings are fixed on the CV joints. I guess you missed that
TUNINGGARAGE
REVO TECHNIK
Old 13-03-2012, 13:43
VWAirlines's Avatar
Originally Posted by 2fast4you
No!!!
Thnx!! I see now
I still have the rear axle parts of the mk5. I'll check it out tonight!
Old 28-03-2012, 20:24
2fast4you's Avatar
OK so here is some work done. Finally we started painting :facepalm: The interior and the engine bay have been painted and in the next few days so should the outside
And some more parts:
APR HPFP
Audi S3 IC
and a NS MKV Offset Dashpod from ECS
Audi R8 fuel pressure valve
Audi Oil Cap :P
and the first thing I will change on my 2.0 TFSI
also updated mu garage with some tools
The only thing that wories me is the size of the IC. It's a bit taller then the Rallye IC ?
but I think I'll find a solution
TUNINGGARAGE
REVO TECHNIK
Old 28-03-2012, 21:19
Dokter D's Avatar
Dokter D Dokter D is offline
Nice project
Old 28-03-2012, 22:02
paint looks great!
Old 30-03-2012, 07:47
CrankWork CrankWork is offline
so much awesomness in this thread!
what does R8 fuel pressure ventil do? it must be important since it's made in japan and not eastern europe lol
also, I'm sureprised to see the follower for HPFP (or what I think the part is) has an expiry date!
Old 30-03-2012, 08:09
2fast4you's Avatar
THANKS
The theory goes like this - The OEM fuel return valve opens at 130 bar and allows pressure to drop to 127 bar,then it starts building pressure back up again until it reaches 130 bar at which point the cycle is repeated. The RS4 valve does not open until the pressure reaches 136 bar and allows the pressure to drop until it reaches 130 bar before it starts building the pressure back up. So a stage 2+ map requests 130 bar of rail pressure therefore this mod should be beneficial, as it will help maintain 130 bar fuel rail pressure rather than fluctuate from 130 - 127 bar with the OEM system.
About the cam follower for the HPFP I juts saw that I really don't know
TUNINGGARAGE
REVO TECHNIK
Old 04-04-2012, 16:58
THANKS
cool, I learned something new. cheers!
Old 04-04-2012, 18:47
2fast4you's Avatar
Glad that I could help
TUNINGGARAGE
REVO TECHNIK
Old 12-04-2012, 21:49
2fast4you's Avatar
Finally Some paint and clear coat :P
Only one thing I have to say:
Just the naked eye can see the real beauty of the finish
Also sone more parts arrived:
I bought NEW all possible screws
and a special ??? thing that goes underneath the fixing points of the front fenders
and another styling detail :P
TUNINGGARAGE
REVO TECHNIK
Old 12-04-2012, 21:51
Old 13-04-2012, 07:31
golfje_295.000's Avatar
that`s really beautiful. Red is THE colour for a mk2.
sick shit.
Originally Posted by Vladi
Old 19-04-2012, 23:57
2fast4you's Avatar
Well the assembly has started
And tinted the windows
TUNINGGARAGE
REVO TECHNIK
Old 20-04-2012, 19:02
VeeDubber's Avatar
Volksforum Crew - S2 Racer
Very nice!
Old 20-04-2012, 22:06
2fast4you's Avatar
More parts from the shopping list have arrived :laugh:
OMP Steering wheel
My racing shoes Alpinestars
Carbone Lorraine brake pads for my rear Camaro SS Brembo Calipers
and some more parts from the VW dealership
TUNINGGARAGE
REVO TECHNIK
Old 22-04-2012, 21:15
2fast4you's Avatar
Some updates
The bumpers, rear view mirrors, front grill came back from painting
TUNINGGARAGE
REVO TECHNIK
Old 28-04-2012, 23:22
2fast4you's Avatar
OK nothing much done but ...
I decided to chrome all mu nuts and bolt so here are some of that:
and more new parts
then started cutting the MK5 dashboard
and at the end I finally installed the brake lines
I painted the front lock carrier, lower cross member and completed the front end and the bonnet because I couldn't wait to see how will the car look at the end :P
TUNINGGARAGE
REVO TECHNIK
