-   Golf and Jetta Mk1 (https://www.volksforum.com/forum/forumdisplay.php?f=67)
-   -   golf 1 cabrio (155) 2H motor temperature light flashing (https://www.volksforum.com/forum/showthread.php?t=146233)
donna 11-04-2024 20:27
my GolfMK1 with 2H motor has the temperature light flashing. Temperature gauge is in the middle, fan works, temp is ok.
Coolant reservoir has no possibility to mount a coolant level sensor. But there is a connector present. So the reservoir could be replaced. Can I connect the 2pins of the connector with a wire (or will it create shortcircuit)?
Or better to foresee a resistor? But which is the resistance ohm value?
