Go Back   Volksforum.com > International > Aircooled technical forums > Type 3 (fastback, notchback, squareback)
Old 02-03-2005, 12:07
Tommy's Avatar
Tommy Tommy is offline
Originally Posted by kruk@b
@Tommy,you can boil your eggs,but can your girlfriend blow her hair ??
Like I would want her to blow her hair... There other things to blow for her...
Old 02-03-2005, 12:15
Big_Mac_Mark's Avatar
they all are beyond repair .....
Most beautifull graveyard ever...
- Golf MK4 2.0, 1999
Old 02-03-2005, 13:37
this amount of snow is soooooo NOT DUTCH :p (too bad we didn't get much here yet. a few cm's max..)
Old 06-03-2005, 18:59
G.I._BOB's Avatar
G.I._BOB G.I._BOB is offline
Today
Bonegrinderz int.
www.vwdepartment.com
Old 14-03-2005, 20:27
PerL's Avatar
PerL PerL is offline
Picture taken today, I hope spring is around the corner....
1999 Audi A6 quattro
1987 Audi Coupe quattro
Old 14-03-2005, 20:47
that's the first pic i've seen of your type3 ever.....
Old 14-03-2005, 20:52
PerL's Avatar
It is? Wow.... I posted it in the aircooled forum on Vortex when I bought it, but didnt get any replies. Have a look at my galleries instead
The 1970
The 1973
Both cars are in a somewhat sad shape right now, but the 70 will probably be on the road this summer. I'm not restoring it, rather doing some kind of custom with primer paint and 17" wheels. I just need to patch up the rust holes, paint the car, and put in new brake lines.
The 73 needs a proper restoration, I dont know when I will get the time for that. It needs a lot of work, among the work that is needed is to put in rust free heater channels (which I have in storage, personally brought home from California)
Old 14-03-2005, 21:04
Beetlefreak's Avatar
It is over here, this week it reaches about 15+ degrees Celsius
It is? Wow.... I posted it in the aircooled forum on Vortex when I bought it, but didnt get any replies....
Well, there are a 'view' () type 3 owners around here, maybe you'll have more luck
It also fills up the international aircooled section
Old 15-03-2005, 08:05
krukab krukab is offline
Default Since the snow's already gone over here ...
but the 70 will probably be on the road this summer ...
... doing some kind of custom with primer paint and 17" wheels.
just curious,but what type of 17" are you going to use ??
Most 17'teeners are 7J wide,and you don't have enough room in the frontwheelarces
You can use Tourwreck 6,5x17 steelies,but rumors are that those wheels came in
Beemers pcd,and that's 5x120 ....
Old 15-03-2005, 13:17
PerL's Avatar
I'm using Momo GT2 in 7.5x17 ET35, and from what I've been told on both Shoptalkforums.com and Germanlook.com, they will fit both in the front and the rear.
Old 15-03-2005, 13:54
I don't think there's any problem at the rear,but at front it's a different story,
unless you want the turning circle of an ocean liner
User-x his ride is running C2 8J's (et52) at the back with 205/45,and up front he's using 6J (et52)
with 175/50x16,but his turnig circle is -even with these small front wheels and tyres- quiet big ...
btw,his car is dropped at the rear one outer spline,and up front to outer splines ... what are you planning ??
Old 15-03-2005, 14:32
PerL's Avatar
I am planning on dropping it a little bit (2 splines up front, 1 rear), but only after the wheels are fitted, to see how much's needed.
