Go Back   Volksforum.com > International > Technical > Watercooled projects
  #201
Old 22-05-2012, 20:06
2fast4you's Avatar
2fast4you 2fast4you is offline
OK, finally something has been done
I got the bolts and nuts from the roll cage and the door locks chromed
bought some cardan shafts (Golf Mk5,Golf mk4,Audi TT 8n)
and glued the dash back together
and then cut and glued the other parts that needed fitting
and at the end how should the interior look like
only maybe without the navigation
TUNINGGARAGE
REVO TECHNIK
Old 02-06-2012, 23:00
2fast4you's Avatar
Well finally I received the last batch if nuts and bolts that went to chroming
and so the work can continue
mounted the front and rear axle, and started on the measuring the propshaft
so everything looking good
TUNINGGARAGE
REVO TECHNIK
Old 03-06-2012, 12:44
Pro FM's Avatar
Pro FM Pro FM is offline
This is one hell of a project! Respect for all the work and efforts to take this into an outstanding car!
Daily /Work: Caddy Highline TDI 2.0 2018 | Fun: Golf Cabrio MK1 1991 G60
Pro FM 24/7 Nonstop Danceclassics & Dancehits
Old 09-06-2012, 22:11
2fast4you's Avatar
Made the propshaft bolt on the original Rallye propshaft holders
I also did a little intervention on the rear axle because the propshaft was a bit off center
then unscrewed the fenders and put a special plastic sealant strip that I bought from the dealer
and then screwed them back on with the new screws and special intermediate zinc plates (they are used so you don't scratch the color )
then installed the drivers seat . The codrivers will have to wait because I haven't received the seat rail for the seat
after all of that I assembled an BWA engine that I had in mu garage with the quattro gearbox and fitted that on the Rallye
there is enough space for a GT3076 I think
and from under the car
there is one problem that will need to be solved
the gearbox as fitted is very close and will hit the front axle
and when the car will be on its wheels ...should look something like this:
then the oil pan will be around 11sm from the ground Dont know if it will be a problem
as you can see its almost the same height as the front axle
TUNINGGARAGE
REVO TECHNIK
Old 16-06-2012, 20:59
2fast4you's Avatar
The lower engine mount finished
and the roll cage painted and half mounted
Still waiting for the big update
TUNINGGARAGE
REVO TECHNIK
Old 17-06-2012, 03:42
That's not bad at all. It's not even the lowest point on the car.
Old 19-06-2012, 17:37
tuner4vag's Avatar
tuner4vag tuner4vag is offline
i think you will have a problem with the gearbox lower mount . the mount should have at least 2 rubbers in order to work properly . the way you fixed it in the subframe it will brake at the first start of the car. i hope i am wrong but give it another thought before you get on the road.
golf rallye
audi a3 tdi quattro
Old 19-06-2012, 19:52
2fast4you's Avatar
I also thought of that and I was thinking of using the MK4 lower mount but leave that aside time for this:
Finally
My big update
Today I bought this:
a 2010 Seat Leon Cupra R
and the hart for the Rallye
TUNINGGARAGE
REVO TECHNIK
Old 19-06-2012, 20:07
Nice!
Old 20-07-2012, 18:54
2fast4you's Avatar
Nothing much done on the car at this time
I tried to clean the gearbox but couldnt so I sandblasted it
installed a new hydraulic clutch pump
then installed the gearbox on the engine and in the car it goes
I started conecting the water hoses and other stuff to see what needs to be modified and when I came to the gear selector :P
I had to drill some nasty holes to get that thing in the right position and length. I used the Audi TTs gear selector because as far as I know it has the longest cables
and it will be tight on the front end but I think I will manage to get the S3 IC and water cooler in there. If the MK5 GTI water cooler fits in there I was thinking of ordering the Mishimoto one and the Mishimoto fans
Closed some of the cable holes
bought an Golf MK4 lower engine mount
and started cutting
and then made this:
and then the final product
and the mount on the engine
also bought the RS4 ignition coils for my engine
Moore to come :wave:
TUNINGGARAGE
REVO TECHNIK
Old 20-07-2012, 19:13
engine support looks good!
Old 30-07-2012, 19:50
2fast4you's Avatar
Finally everything I need for my rear brake set up
CNC machined adapters :
2sm H&R spacers
And the finished product
TUNINGGARAGE
REVO TECHNIK
Old 30-07-2012, 21:40
VeeDubber's Avatar
Volksforum Crew - S2 Racer
Looking good! (again)
Old 30-07-2012, 22:09
2fast4you's Avatar
Thanks !!!
TUNINGGARAGE
REVO TECHNIK
Old 01-08-2012, 23:06
2fast4you's Avatar
OK ... I found some time to play with the rear ABS sensors:
First I made a ring so I can get a little space
and i got this:
tried this but this way the sensor is short
then started making space so I could push the ABS sensor from the inside out
but this way the sensor came out too much
and then decided to do some cutting so:
and got this:
the only problem will be the fixing the ABS sensor ... but with all the glues out there I thing It's possible
If someone doesn't understand what I am trying to do :
also the calipers and adapters are in filler and painted :
TUNINGGARAGE
REVO TECHNIK
Old 14-08-2012, 23:08
2fast4you's Avatar
Still waiting for the big stuff but here is some small updates:
A little touch of Carbon
the rear door magnet motor (will be opened with this)
Because I will be going for stage 3 I mounted the RS4 injectors
rear brakes done only waiting for the logo
Golf MK5 GTI wiring
chopped up
and the garbage
TUNINGGARAGE
REVO TECHNIK
Old 16-08-2012, 21:25
CustomCarAlloy CustomCarAlloy is offline
Adverteerder: Custom Car Alloy
Love it!
Specialisten in hoogglans verdichten
www.customcaralloy.com
info@customcaralloy.com
Old 16-08-2012, 21:29
Amazing detail
Old 02-09-2012, 22:41
2fast4you's Avatar
OK finally something getting done
wires for the Haldex all sorted out( The wiring is from a Golf MK5 GTI)
set an MK5 R32 power distributor ... because mu battery will be at the back of the car
the inner wiring
and finally after 3 months of waiting and a set of lost seat rails here they are...
I also bought an K&N filter cone
Many more parts bought and on they way from the US... it will be a long wait
TUNINGGARAGE
REVO TECHNIK
Old 02-09-2012, 23:05
i hate wiring....
And i think i've said this before, but i hope you're not keeping track of your receipts.. The amount of new goodies that are going into this thing are insane.
