Go Back   Volksforum.com > International > Aircooled technical forums > Type 1 (beetle '49->)
  #41
Old 28-02-2008, 22:59
robertjan007's Avatar
Damn man... It make's me very very happy!!! What a nice project!
Good Luck
VW OUTLAWS
Car & Radio Blog
Old 01-03-2008, 18:36
DrLaban's Avatar
DrLaban DrLaban is offline
*Update*
Completed my transmission today.
Converted to short axels, new bearings etc.
Old 02-03-2008, 12:21
vwouter vwouter is offline
Originally Posted by DrLaban
*Update*
Looks very nice.
But there is one thing you should change. The bolts on the rubber that's mounted on the axles and the gearbox should be pointing to the back or the front. The way they are sitting now, they will screw up the rubber, each time your suspension will go up and down.
Old 02-03-2008, 16:53
DrLaban's Avatar
Originally Posted by vwouter
Looks very nice.
I have changed that allready
Old 02-03-2008, 18:11
steven16v steven16v is online now
Damn that looks hot!
A very nice project! Good luck with it!
Old 02-03-2008, 22:25
DrLaban's Avatar
*Sunday's update*
It sonny day in Oslo today, but I desided to spend the hole day in the garage
New breaks, incl. new emergency brake cables.
Completed the Air Ride @ the rear.
I also had to "try" this one, EMPI shifter
Before I closed the garage I started on the front suspension.
Removed all the caps.
To be continued....
Old 02-03-2008, 23:52
DrLaban's Avatar
Wait till you see them on the car with the tires
Old 03-03-2008, 23:11
DrLaban's Avatar
*Update*
Spent some hours in the garage tonight after work
I continued with my front suspension. Used the grider to get a flat surface for the big washers.
Got most of the grease out of the suspension, but to be on the safe side I taped the end so I didn't get any grease inside the replacement bar.
Both inserts in place..
After some work with the "Dremel" I got the prefect fit for the washers
There will be a little special bearing between the big washers, but I need to buy some Locktite before I tighten the bolts.
Voila..
Old 05-03-2008, 22:17
DrLaban's Avatar
*Update*
Bought some Loctite yesterday and was ready to complete the front suspension
Installed those strange bearings between the washers. I added some grease on the bearing before I installed the bolts.
Used the Loctite on all 4 bolts to be sure that the suspension don't collapse
Everything in place..
Then I installed the Air Shocks in front. I have to drill som bigger holes in the spindles before I install the drums and breakes.
Old 07-03-2008, 07:28
DrLaban's Avatar
*Update*
Last night I drilled new and bigger holes in my drop spindles and installed the flip rod kit. I am flipping the outer tie rod upside down to get a better angle when the car is so loooow
The kit is installed like this..
Ready for installing breaks etc.
I needed to modify my rear drums after converting to short axels
And here's the result...
Old 07-03-2008, 18:14
DrLaban's Avatar
*Friday update*
I am now ready to install the wheels and drop the car to the ground
Need the finish the wheels this weekend so I can get some tires on them next week.
Old 08-03-2008, 00:23
DrLaban's Avatar
*TOUCHDOWN*
I had to find out how low the car is now, before I get the tires. So after finding the right height of my tires, I made some temporary ones
A BIG smile in my face when this happend. And I still got more travel in front
30mm clearence @ the edge...
And @ the rear. 8 inches of pure rawness
Old 08-03-2008, 00:26
wow, touchdown is right,... this thing is gonna be insane.
Old 08-03-2008, 07:26
Ferry24's Avatar
Ferry24 Ferry24 is offline
sweet!
Rachistorie
Old 08-03-2008, 12:27
Marcski's Avatar
Marcski Marcski is offline
i thought load adjusters were supposed to be used in combination with ordinary suspension and not carry the entire load
don't you think the vents will be too small (read slow airride)?
Old 08-03-2008, 13:12
DrLaban's Avatar
This isn't ordinary load adjusters/hijackers. These are air shocks which replace both the shock and the spring. I had the same type of air shocks @ the rear on my Golf 1 Cab project. Working like a charm en carries the weight without problems.
I haven't bought a fast kit... I am not going to stand beside my car at the shows and "wiggle" and jump. I have installed the ride to be able to have my car extremly low, but still be able to raise it if can't get over something.
Old 08-03-2008, 13:57
Stijn's Avatar
Stijn Stijn is offline
Class of 2003
Insane! Mad props yo
Interesting front airbags/springs/shocks, where did you find those? Would be usefull on various cars...
Connie: 16.
Quagmire: 18? You're first.
Connie: Mom!
Old 08-03-2008, 14:35
DrLaban's Avatar
I bought the complete Air Ride from Airkewld in the US.
Old 08-03-2008, 15:23
Marcski's Avatar
just wondering, cause they look exactly like em, even the nozzle..
Old 08-03-2008, 15:52
DrLaban's Avatar
That's not a nozzle.. it's the protection cap
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
