Go Back   Volksforum.com > International > Technical > Aircooled projects
Home Shop FAQ Register Members List Calendar Today's Posts
  #41
Old 24-12-2007, 15:19
Tiki Madness's Avatar
Tiki Madness Tiki Madness is offline
Volksforum Triple Action Donor - Half a brain dragracer
wheels are in!!
michael
I got kicked out of Barnes and Noble once for moving all the Bibles into the fiction section.
Old 26-12-2007, 16:00
vandaag toch nog wat gedaan,ben begonnen met het verstevigen van de voorkant.Helaas hed ik te weinig buis om dit af te maken,morgen beter.
Ook het dashboard aangekleed om te kijken of ik de schakelaars voor de ontsteking en de brandstofpomp er ook nog kwijt kan.
michael
Old 09-01-2008, 22:01
mounted the tank and fuelpump this week,
the tank holds 1 gallon which is 3,7 liter.
also, i welded a towhook to the rollbar, in case it ever needs towing
this will pertrude the windscreen.
michael
Old 09-01-2008, 22:15
Gijs's Avatar
Gijs Gijs is offline
Volksforum Crew - Gijsmans
looking good !
That coppercolored thing on the frontaxle is the fuelpump i presume??
'06 Passat variant TDI+ 4Motion
'00 Golf VAN Variant ex-ANWB TDI
'96 Golf GTI 16v trackday
'91 Golf Syncro Country
'89 Golf CL VR6
'87 Golf GTI 16v ex-rally
'81 Transport Pick-up
'79 LT35 2.4 Diesel
Old 10-01-2008, 08:14
evilnyntje's Avatar
are you gonna do a plexglass windscreen?
My Swallowtail
Flake It!
Old 07-05-2012, 23:40
Michael
Old 07-09-2012, 21:12
It's been a while but I'm still working on the car. Searching for parts consumes a lot of time and changing my mind every day doesn't help either
But I decided to ditch the renault gearbox and put a 091 in. Got a lead on a really good one ;D ;D.
I'm also going efi so I bought an IC and have to make a new intake and exhaust so why not make everything a little bigger and get a bigger turbo.
Sold all the draw through stuff so there is no turning back now ;D
Michael
Old 08-09-2012, 17:56
New waste gate
Michael
Old 27-11-2012, 00:54
Took some time to take some pictures from the modifications Jim made.
Some people pointed to me that the front didn't have enough tubes so I had Jim add some more.
I think it is safe now.
Fitted a vertigate shifter,
Down pipe almost ready,
Box fitted with plates.
Michael
Old 27-11-2012, 23:12
Michael
Old 05-12-2012, 00:09
Old 03-01-2013, 11:35
Put the twin fuel pumps in yesterday.
Mow all that I need is a fuel pressure regulator and this little project is finished
Michael
Old 01-02-2013, 20:32
been trying to work o the car again after been sick for a few months.
Started on the aly panelling
Michael
Old 23-02-2013, 21:47
finished plumbing the front side of the car
And all the aluminium is done up front,
Finally gave my shop a good clean up ;D
Now it's of to the volksworldshow at the end of the month and pick up a pile of stuff to get it closer to completion.
Michael
Old 24-02-2013, 20:42
Whoooooot!
Old 17-03-2013, 14:03
Due to the cage I can't fit the rods from the MSE in a straight line. I asked Jim Smith how to solve this problem and he gave me some info in to the right direction. Thanks Jim ;D
When the gearbox is in I will make rods with uniballs going from the pivot to the gearbox
Michael
Old 07-04-2013, 17:08
Been putting in some late hours last week as I got my gearbox now. First thing to do is make it shift,due to the funny car cage I had to make a pivot to re align the rods.
It looks like it will work all I need now is the "forks" that attach to the gearbox.
I then started working on the Co2 launcher.
That's mostly done also.
finally I put my tires on the new rims.
Michael
Old 04-07-2013, 19:33
CarlKever's Avatar
CarlKever CarlKever is offline
Found your topic, I'll stay up-to-date on this forum.
Een mening is altijd subjectief en nooit objectief.
Old 26-01-2016, 20:16
Any updates on this?
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
