Old 02-11-2005, 09:42
falco's Avatar
falco falco is offline
Default Alpine v12 versterker
Heb nog een alpine versterker liggen type v12
12 dB / Octave LP/HP Continuously Variable Crossover (30-200 Hz)
1-Band Parametric EQ (30-200 Hz)
Subsonic Filter (15 Hz)
Extra Large Gold Plated Terminals with Wire Insert Capability
Top Panel Power LED
4V Input Capability 2-Channel Amp Specifications
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 70W x 2 @ 12V
THD at 4-Ohm RMS Power: 0.08%
Bridged RMS Power @ 4 Ohms: 240W x 1 @ 12V
Speaker Level Inputs: No
Preamp Outputs: No
Built-In Crossovers: HP/LP
Bass Boost: 12 dB
Frequency Response: 10-50,000 Hz
Signal to Noise Ratio: 105 dB
Fuse Rating: 2x20 amps
Prijs €130,00
