Go Back   Volksforum.com > International > Technical > Aircooled projects
Old 10-04-2015, 23:30
Ben Modified's Avatar
Ben Modified Ben Modified is offline
Default 1961 V8 Single Cab Street Rod
I purchased the rotten cab and bed gates and added the rest. It uses a 400 Hp GM crate engine with a custom made frame and street rod suspension.
My Build Blog with all Projects
YouTube videos of the Build
Old 11-04-2015, 00:12
Amazing. Keep us updated!
Old 11-04-2015, 02:33
Van Limburg's Avatar
Fun build!
Old 11-04-2015, 02:40
I just wasted two hours on your blog.
You are an amazing engineer and extremely creative!!
Love the cushman and Toyota van!
Old 11-04-2015, 02:53
Thanks! Did you check out the Pedal Motorcycle?
Old 11-04-2015, 09:54
Pro FM's Avatar
Pro FM Pro FM is offline
same here... i really like the electric VW bus because the fact it looks totally original. But i also like the other ones which are very creative.
Keep up the good work!
Daily /Work: Caddy Highline TDI 2.0 2018 | Fun: Golf Cabrio MK1 1991 G60
Pro FM 24/7 Nonstop Danceclassics & Dancehits
Old 21-07-2015, 20:45
Custom floor going in
Old 22-07-2015, 07:09
Holy smoke, that is going to be insane!. Love your projects on the blog, it really shows your are extremly creative
Old 22-07-2015, 19:35
Thanks so much!
Old 22-07-2015, 21:38
hajee's Avatar
hajee hajee is offline
amazing!
Old 28-07-2015, 00:11
Default Single Cab Street Rod
The floor is finished and have started on filler panels for the old highlight bucket area.
Videos of the Build:
Old 30-07-2015, 15:11
I have had a few requests for more information on the shop/projects. If you are interested, here is the link.
Shop Tour
My YouTube Home Page
Old 05-08-2015, 01:12
Default Brackets
Still need to smooth and finish
YouTube link to my Build Videos:
Old 05-08-2015, 01:50
Still love everything about this!!
Old 05-08-2015, 06:08
Insane! Love it!
Your lucky there are no speedbumps on the road. O:-)
Old 07-08-2015, 02:41
Old 08-08-2015, 02:22
Default Adapted front shocks to the Speedway Front End
I used these small Monroe golf cart shocks. They were a perfect fit. The piece of tubing will be removed.
YouTube link to build videos:
https://www.youtube.com/user/TheGreenVW/playlists
Old 11-08-2015, 00:44
I decided to try and use the factory headlights and buckets on the single cab. I installed one today. It moves with the steering.
Old 11-08-2015, 07:21
Nice!
Old 12-08-2015, 00:40
I went ahead and mounted the other headlight, although I may not keep them. Also added the other shock tower bracing. Still need to finish the welding and smooth.
Trimmed off the bottom of the door and started making a template for a rocker panel.
My Build Videos:
