#41
![]() I love this built
Welcome to the internet: Where men are men, women are men, and little girls are FBI agents. |
#42
![]() Thanks mate
#43
![]() What should have been finished has been put onto the back burner due to demanding wife
![]() Sad times .....life used to be so good [:[] ![]() ![]() ![]() The old plants sitting idle two years now ![]() ![]() Last edited by fasteddie : 05-12-2014 at 22:36. |
#44
#45
![]() Why are all the posts deleted?
#46
![]() Mmm, sad.
#47
![]() Been Busy and fell out with the woman
![]() killed ...Sorry guys ...been busy fixing them and even done a bit more on my dub ![]() |
#48
![]() Airbox time [:s]
Foam is falling to bits and I hate things not right, so had to come apart ![]() Think most look something like this now ![]() ![]() Best to split to remove flaps ![]() Old foam removed and found some new foam from mk4 golf door panel speaker blanks ![]() ![]() All cleaned and good to go, just going to get more foam tomorrow ![]() |
#49
![]() ![]() Last edited by fasteddie : 14-10-2016 at 13:37. |
#50
![]() ![]() Last edited by fasteddie : 14-10-2016 at 13:38. |
#51
#52
![]() Just getting the last bits I need to finish her then hope to get stuck in again next month
![]() Went to creationsmotorsport_uk For the Mk2 to Brembo brake lines ...nice and easy and came the next day ![]() ![]() Then after a bit of searching I managed to find a set of flat center caps for my Rays, with the Black longer nut covers will be sweet ![]() Wee note.... These would not have fitted the car before as the standard bearing hub cap stuck out to far, but running polo gti ones now. Same colour as rims and Alloy. ![]() ![]() Pic on Rim ![]() Here like Whats the craic you lot [:[] Been well busy ![]() Cover removed ![]() Nice and tidy ![]() ![]() Can't beat a nice bit of blue office carpet ![]() Wiring tidied up unwanted plugs and wiring removed ![]() ![]() ![]() ![]() ![]() ![]() ![]() Look tape next ![]() ![]() One loom done and in the car next up engine loom Got a fair bit through it tonight ![]() ![]() |
#53
![]() Both looms now sorta sorted just to run them down legs and find a place for ecu
![]() Wee drop of wax round boots seen mk2's rust round these holes ![]() ![]() Had a new servo sitting in my loft New and old ![]() ![]() ![]() Seat Ibiza Cupra R master cylinder and Ford focus one on car ![]() ![]() ![]() My new center caps from Japan ![]() These wheels don't come with center caps when you buy them ![]() German Performance wheel of choice ![]() Wee links Click on ![]() https://www.google.co.uk/search?q=P...iw=1440&bih=775 https://www.google.co.uk/search?q=P...k+Te37&tbm=isch ![]() ![]() ![]() ![]() The power cable to hide battery in the car ![]() Dash in to see what room I have under it for ECU tis looking good ![]() ![]() Wiring and more wiring [:s] Working through wiring today, wanted to utilize the holes in the shell Nice wee blanks in the chassis, removed these and found me some Vag Grommets to fit in nice ![]() Front wiring and plugs ![]() ![]() ![]() ![]() ![]() ![]() Ran the rest of the wiring through scuttle to hide it and take part of it to the ecu in to car via the heated washers wiring grommet ![]() Wiring ran down both legs and brought up through leg to the washer motor and a loop earth I added ![]() ![]() |
#54
![]() Sorting battery cable and finishing wiring earths etc
![]() ![]() To wiper motor and the other to Emerald inside car ![]() Battery cable Grommet in leg and lighting wiring run ![]() Center tail is for sensors and starter etc ..right hand tail is for level sensor in coolant bottle ![]() loop earth ![]() ![]() ![]() |
#55
![]() Battery cable sorted ..bit of G sheet cut to fit the inset and keep feed cable safe and reseal floor
![]() ![]() ![]() Bit of hard wax sealer ![]() Where it comes out ![]() ![]() sorted ![]() ![]() Next up was sort out the wiring on rear of Dash New feed added etc ![]() Dash fitted ![]() My Wideband and anything else you want, it does it all ![]() ![]() Cover time ![]() ![]() Quiet day do going to make a few pipes up ![]() Everything you will need, you can get brake pipe pliers but not needed wee alloy bar with a cutout I put in it does everything I need. Thing I don't like is copper/nickel copper pipe as its not factory looking also copper goes off and looks crap ...so mine will be copper/black [8D] more pic's soon ![]() ![]() ![]() Work out what length you need and leave a bit on so once you shape it, then trim if need be before fitting nut ![]() Wee pipe cutter ![]() Make sure end is flat ..wee file ![]() ![]() Pop in ![]() ![]() ![]() Job done ![]() Shape pipes by hand and finish them once clipped into place ![]() So far so good ![]() ![]() Clipped and wee heat shield I made added ![]() ![]() Next up was drivers front pipe which comes back across ![]() ![]() ![]() ![]() Last to finish front was passanger side pipe ![]() |
#56
![]() The Brake shield, seen these on Subarus so made on for the Dub out of wifes special K box
![]() ![]() Cardboard wasn't going to fly so ..... ![]() ![]() ![]() Bit of an after thought ![]() ![]() ![]() ![]() |
#57
![]() Pipes all finished, just need to bleed
![]() Looks better than copper ![]() ![]() ![]() ![]() Rear pipes Sorted ![]() ![]() Bleeding sorted ..pedal good ![]() ![]() Back on her wheels and side skirts fitted ![]() ![]() ![]() ![]() Back under cover [!] ![]() |
#58
#59
#60
