Go Back   Volksforum.com > International > Technical > Aircooled projects
Old 15-09-2013, 07:37
Fiatdude Fiatdude is offline
Default Rebuilding my 2963cc engine
Thought I'd share a few photos of the freshen/rebuild of my engine. This engine uses ARPM case, 4" (103mm) siamese barrels and angle port heads -- this engine was orginally built in the late 80's and has been setting around until a couple of years ago when I decided to try to use it in my oval and now my Ghia.
Here is a picture of the inside of the case with the 90mm Pauter crank in place -- this case features a .120" drop cam so that the cam doesn't need to be clearanced when using this large of a crank
Here is the ARPM case together with the J&E custom pistons hung on the rods.
Here is the siamese cylinders installed -- you can see the the differences over stock and the see the 6 13mm studs used to hold everything together
Here are the angle ports installed -- will be pulling these back off sometime soon as I'm going to pull the K800 springs off and switch to some bee hives. Also switching from the 3 piece shaft Pauter rockers to the new 1 piece shaft Pauter rockers
Here is the complete engine -- it is BIG -- 34" across from valve cover to valve cover -- -- I think a stock engine is in the range of 28" across
Old 15-09-2013, 08:45
Dokter D's Avatar
Dokter D Dokter D is offline
Nice engine!
Do you have more specs?
Old 16-09-2013, 04:21
it is a 90x102.4 -- what other specs do you want
Old 01-10-2013, 23:53
That thing is huge!
