Go Back   Volksforum.com > International > Aircooled technical forums > Type 2 (bus '49-'67) (bus '68->)
Old 28-06-2005, 08:52
1200jubi's Avatar
1200jubi 1200jubi is offline
Smile Porsche Cup I on a T2b
Hey!
I have a question! I would like to put Porsche Cup I in 7,5x17 ET 52 on my VW Bus T2b Bj. 75 with adapters which are 20mm pro side. Is this without work possible on the rear side?? Or do i have to work for the rear wheels???
Mfg 1200jubi
Old 28-06-2005, 08:56
krukab krukab is offline
They will fit without any problems
At front I'm running 7,5x17 et47 with 25mm adapters,and at the rear I mounted 9x17 et47 with 17mm spacers
(I redrilled the hubs an drums,because there wasn't a 17mm adapter available at that moment)
Old 29-06-2005, 21:03
1200jubi's Avatar
Thumbs up
Hi!
You mean it won´t be a problem to get the 7,5*17 ET 52 to the back-side with 20mm Adapters? I hope that i get the adapters tomorrow or on friday than we will see *gg*
Thanks for your reply!!!
Old 30-06-2005, 06:44
Before my 17" Turbo's,I had some 964 C2 wheels fitted,and those where 8x16 et52 with a 25mm spacer.
They as well fitted without any problems or tyre rubbing in the rear wheel arces.
Tyres where 215/40x16 .... what kind of size are you putting on you're 17"'s ??
I also had some 8x17 et70 ( ) at one moment in time,and those tyres were 225/45x17
Old 05-07-2005, 09:36
1200jubi's Avatar
hi!
They are 7,5*17 ET52 with 20mm Adapters at each side. The wheels are 215/45/17. I got the Adapters today and I´ll try them at the weekend. Will see.
nice wishes
1200jubi
Old 08-07-2005, 07:01
1200jubi's Avatar
Post Adapters
Hey Kruk!
Yesterday I put the Cup I on the Bus - they fit perfekt! Can you tell me, how I can put the Bus DOWN in a cheap way? How much do you think is the bus on the picture puttet DOWN?
nice wishes
1200jubi :biggrin:
