Go Back   Volksforum.com > International > Technical > Wheels and tires
Old 24-08-2010, 16:44
Chromosexual's Avatar
Chromosexual Chromosexual is offline
Default Did VW ever make 4x100 16" OEM VW Steel Wheels?
Looking for a set that I dont have to bore out the hubs or do anything but slap on rubber, bolts, hubcaps.
Anyone have any clues if VW ever made em in 16's?
-Paul
no new friends
Old 24-08-2010, 19:46
RubenD's Avatar
RubenD RubenD is offline
No, they haven't.
In the Netherlands people usually use Opel (Vauxhall, Holden, GMC) steelies or Mini's I believe.
Old 24-08-2010, 19:52
Marcski's Avatar
Marcski Marcski is offline
Yup, New Mini winter steelies are 16" 4x100, you just have to widen the centerhole from 56,1 to 57,1
Old 18-10-2012, 15:42
Does this do the trick?
Old 18-10-2012, 18:13
fearless's Avatar
fearless fearless is offline
Huge centrebore, use vauxhall rims...With a bigger centrehole (bore it out)
So they will fit snuggly on your wheelhub, its going to shake if you havnt got them centred straight.
Old 18-10-2012, 18:35
hajong's Avatar
hajong hajong is offline
Or you could try to find Renault Megane 6,5x16" ET49 steel rims. Centerbore (60,1) is bigger than VW, but still 4x100.
Vive Ernst Berg!
Old 18-10-2012, 19:40
Don't see the centerbore as a very big problem though on steelies...
Old 18-10-2012, 19:41
fearless's Avatar
You can't centre the wheel on the bolts only....
Its going to shake your bolts loose at some time.
