Go Back   Volksforum.com > International > Watercooled technical forums > Golf and Jetta Mk2
Old 16-02-2005, 11:24
Housey's Avatar
Housey Housey is offline
Send a message via MSN to Housey
and now we want updates!!! i'm droooling for more pics and specs! not everyday you see a TDI i'm a mark 2 golf! rock on!
Old 16-02-2005, 15:18
pikzibner's Avatar
pikzibner pikzibner is offline
Send a message via ICQ to pikzibner
Soon soon. The car is 300 km away from me. So I'll tel him to send samo pics. But I need some more parts. 1 engine carrier missing, need golf 3 tank, need some screws, metal heat insulation from Golf 2 GTD, need brakes from GTI 16V and we'll put on 288 mm disc wirh pillow from MK3 '97 VR6. And some more stuff.
Old 16-02-2005, 16:46
pikzibner's Avatar
Updates:
Old 16-02-2005, 23:05
Rallye 1.8T Rallye 1.8T is offline
Hello!
I am building this car so here are some specs:
Tdi 130 HP,6 speed gearbox
fabia driveshafts
288 VR6 brakes
front axle original 1.6D golf
We won't use VR6 front axle because it is too wide and tyres will rubbing
All motor mounts from fabia
water radiator and clima radiator from fabia
all hoses from fabia
complete wirig from fabia
fabia dash with complete heating
pedalbox: electric gas pedal and hidraulic clutch from fabia,brake pedal from golf (no ABS, golf 16 V master cilinder) this need some welding...
I cut dash about 10 cm under widscreen,and I cut some metal from firewall to make room for heating box
Today is third day of work and I hope this will be finish in about two weeks
Old 16-02-2005, 23:14
Adriaan's Avatar
Adriaan Adriaan is offline
Send a message via MSN to Adriaan
There was this joke about skoda: meneer 1 "heeft u ruitenwissers voor mijn skoda?" dealer: "dat lijkt me geen goede ruil!"
translated: Mr 1 "Do you have windscreenwipers for my skoda?"
dealer: "That doesn't sound like a good trade" (he is implying his wipers are of more value)
anyway, those days are over, Skoda is VAG now! Project looks fingerlickin' good!
Representing de Golf 4 / Bora en TDI motoren!
Old style meets new style! :p
Old 16-02-2005, 23:22
Pikzibner says: " Ĺ*KODA INSIDE"
Old 16-02-2005, 23:46
insane project, and moving VERY fast.. finished in 2 weeks!!
Old 17-02-2005, 01:05
super project!! never seen this before! (with this block/dash)
keep up the good work!
Old 17-02-2005, 08:03
Housey's Avatar
i need to watch this to the end! looks nice! and bet it will go fast aswell! 130 diesel HP in a 1000kg car... whoa
Old 23-02-2005, 11:00
Housey's Avatar
updates?
Old 24-02-2005, 22:32
Maybe more than two weeks...
7 days was sun,then rain,snow,rain and finally today sun.
I haven't garage.
It wasn't snowing in last 10 years... till now
New pics maybe tomorrow.
Old 25-02-2005, 10:36
Housey's Avatar
well, its snowing here... (was) and its 'bout 25 centigrades below ... so... its COLD here! so don't rant
Old 25-02-2005, 21:51
Engine is dropped in.
Pics maybe in morning.
Old 26-02-2005, 13:27
pikzibner's Avatar
Updateeeeeeeesssss:
Old 26-02-2005, 20:07
Matheo's Avatar
Matheo Matheo is offline
cool project! keep on postin'
'06 A4 1.8T Quattro
'85 Transporter
'85 Golf
Old 27-02-2005, 00:02
Marco's Avatar
Marco Marco is offline
Volksforum Crew - Elekit
Holy Crane !!
Passat B1 LS
Passat B8 Businessline R
Old 25-03-2005, 18:04
Danna16vt Danna16vt is offline
Updates ?
Old 25-03-2005, 18:25
mark_84's Avatar
mark_84 mark_84 is offline
nice project i going to follow this
Old 29-03-2005, 07:19
Housey's Avatar
how many newtons is there in this engine? and, are you going to chip it up to about 180hp?
Old 29-03-2005, 14:13
pikzibner's Avatar
Lot's of new things but no pics! We had problem with brakes, with speed and distance measurings, with mounts, ....
I wanted to put VR6 288mm brakes but they can't be mounted on MK2 steering knuckles and I didn't want to put parts from MK3 because my tires allready rubs and with mk3 parts is going to rub so much more. I decided to put G60 brakes and drilled discs to 5 holes, but new problem was audi tt lug with 5 holes because tt lug is 1-2mm bigger on diameter and G60 disc doesn't go on. New problem was speedmeter, because there isn't speed sensor on gearbox. The comp takes readings from abs. So I had to find out are the fabia and tt lugs the same. And we had to put Golf MK4 carrier instead of Fabia's. Waithing for new problems
