Go Back   Volksforum.com > International > Aircooled technical forums > Type 1 (beetle '49->)
  #221
Old 15-04-2009, 12:26
Larsv5's Avatar
Larsv5 Larsv5 is offline
Show us more mate.... Love this project...!!!!
greetz Lars
Dodge RAM 1500
Old 19-04-2009, 21:52
DrLaban's Avatar
DrLaban DrLaban is offline
This weekend I have completed the modification of the ASS. "I love big butts" so I wanted to make one reeeal fat one.
The SEBRING exhaust didn't fit perfectly so I had to re-weld the exits. I also changed to pipes to 2,5".
Made some half moons in the blade
So after a LOT of meaturements, grinding, calculation and brainstorming things looked like this.
The pipes nicely dives into the rear bumper, just the way I wanted.
One BAD ass!
I have changed the shape of the bumper blade, lowered it, raised the exhaust exits, shorten the bumper brackets and shorten the pipes.
Old 19-04-2009, 22:01
like many other things on this car that MUST be a first for a beetle..
Old 24-04-2009, 20:21
DrLaban's Avatar
I am still modifying my front bumper and brackets. Here's a little "sneak" of what's goin' on.
Bumper is now in the perfect height and distance from the front. I have also modified the fog lamps (that I used on my old Galf Cab project) so they don't need a foot or bracket.
I also went and blasted/primed some parts last night.
Just now I am putting all the new air parts together. This is what you need for controlling one corner of the car. In other words you need 4 of this rig to controll all corners.
And some more "sneaking"
Started the upgrade of the air ride today. This should give the system enough air flow. Upgrading from 1/4" to 3/8".
Since the 5 gallon tank is mounted behind the gas tank I had to modify the tanks foot.
It looked like this before I started cuting it:
And after some welding it looked like this:
Will continue the work with the upgrade tomorrow.
Old 25-04-2009, 17:08
knarfmk1's Avatar
knarfmk1 knarfmk1 is offline
nice work!
Old 25-04-2009, 18:53
DrLaban's Avatar
Today I started with the MDF floor which will support all the air management parts.
Started up making a frame under the gas tank. All the other panels will be "connected" to this frame and in that way locked to the body of the car.
Then I made two more panels, one for the air parts and one for the audio amp.
This is the layout, so far. I think there will be some small changes on the location of the air parts.
Now I'm going to make some neat panels which makes it possible to hide cables, air lines etc.
Tomorrow I am also going to make the box for my subwoofer(s), so I can get ride of the MDF-board inside my garage.
Stay tuned!
Old 26-04-2009, 23:19
DrLaban's Avatar
Another sunny day in Oslo. A day spent in/outside the garage
Starting to look like a car again. New seats and panels in dark red. Looks great againts the flat savannah beige paint
Box for the subwoofers under construction. 2 x RF 10" are going inside this box.
Almost done. The inner walls between the woofers are missing in this picture. Each woofer have its own encloser.
Finito Haven't decided what material I'm gonna use on the box. I want it to look original and not look like a sub. So if someone got some pics of a original "plate" behind the rear seat, please post it her.
Old 26-04-2009, 23:27
RubenD's Avatar
RubenD RubenD is offline
Old 26-04-2009, 23:34
DrLaban's Avatar
Originally Posted by RubenD
Yes, is that a original one? Never seen one like that.
Old 26-04-2009, 23:37
as you can see in the link Ruben posted, it's an old Kamei piece
Old 27-04-2009, 15:55
Beetlefreak's Avatar
Yes it is! It's called "Parcel Shelf" and made by Kamei. They are made in red, black and white.
It's a 60's product as far as I know. But the '67 one is different, it has a knob that matches the '67 dashboard:
Old 28-04-2009, 13:33
DrLaban's Avatar
Got all my fittings today. And then I was able to finish the valve/tank setup.
Pretty pleased with the result. Tonight everything is going in to the car, and hopefully soon the car will be on the wheels again.
Old 28-04-2009, 22:53
DrLaban's Avatar
More done tonight, this is going the right way so far
Almost finished "all" the electrical stuff in the car. Fuse panel, lights etc.
I also gave the tank for the air ride a "makeover". So after a couple of hours, it looked like this:
Old 28-04-2009, 23:20
is that a sticker? or are you the best pinstriper ever??
Old 28-04-2009, 23:23
DrLaban's Avatar
It's a special vinyl decal bought in the states. Looks almost real.. kinda scary actually
Old 29-04-2009, 23:25
DrLaban's Avatar
I made a small board under the tank to easy the installation into the car.
Then I don't have to f**k around under the tank to take it in and out. The bolts are VERY tight under it.
Installed I also installed the modules for air management and remote controll (pop doors)
Not much space, but enough
My remote got 3 channels, so I'm going to use the 3. channel for slamming my ride using the remote.
The plan for tomorrow is to blast my bumper blades...
Old 30-04-2009, 20:50
DrLaban's Avatar
The air management is now functional
Tthe 9-switch box. Enables all kind of control. One corner, one side, both front, both rear and all corners.
http://www.youtube.com/watch?v=NQNx...feature=channel
I can also slam and raise using the remote for the shaved doors.
http://www.youtube.com/watch?v=_2WN...feature=channel
Old 08-05-2009, 22:24
DrLaban's Avatar
A little update from the last days. Got a lot done and here's some of it.
Blasted and primed my wheels. Next is bondo and new paint
Also got my red bands..
Modified and fitted my stone guards (ROBRI repro's) A helluva job to get them fitted ok. But after some hours they where on.
More to come this weekend
Old 08-05-2009, 22:27
it's getting there....
Old 09-05-2009, 00:08
Stijn's Avatar
Stijn Stijn is offline
Class of 2003
It sure is!
Connie: 16.
Quagmire: 18? You're first.
Connie: Mom!
